Howdy, Stranger!
Need Help
@Admin Help me please. I tried using the Directory Privacy option in Files in cpanel, but now I am unable to remove that authentication popup. Kindly help. These are some images attached for reference-
  • You can disable directory authentication manually by looking for the file called .htaccess in the corresponding directory through a file manager or FTP client. You can remove the authentication lines from the file manually.
