Howdy, Stranger!
The Weirdest Problem With HTTPS!(NOT KIDDING)
Hello InfinityFree Community.
I have a website,spesifically www.pctips.gq.
I used CloudFlare to get free Flexible SSL.
However,now my website in HTTPS looks completely different and damged than in HTTP!
Can anyone help me,especially @Admin ?
Thanks.
«1
Comments
  • It didn't help me :(
    Anyway,does it have anything to do that in Softaculous I selected HTTP instead of HTTPS?
    If then how can I change it to HTTPS?
    Please @Admin anwser,I can't find it myself :s :/ :/
    Did you verify that you completed all three steps in the article?
  • @Admin The Problem is that to get my content delivered through HTTPS as described in the third part:> Make sure all urls use HTTPS
    If your website has a valid SSL certificate and is using https, but you do not see a green lock, this is because some of the URLs on your website do not use https.
    To get a green lock, all urls on the page must use https. All images, CSS and JavaScript files on the page must be loaded over https or the page will not be considered secure.
    There are multiple ways to look for http urls. Sometimes, you may see "Mixed Content" in the JavaScript console in your browser, with the http URL next to it. You may also be able to view the source code of the page in your browser and look for http URLs there.
    The next step is to find out what generated the bad URLs and how to fix them. Unfortunately, there is no general method to do so: it depends on many aspects of how you built your website.
    i had to select https through sotaculous but now it is on http.
    How can I change it?
    I disabled redirecting all content to HTTPS due to this problem but I am re-enabling it now.
    Please have in mind that I can't make changes through wordpress when I am in HTTPS mode.
  • Ι am really sorry for the pressure and trouble I put you into @Admin .
  • So?What Happened?Did you find any solution?
    BtW i found that some of my url's are still deserved through http (I found itthrough source code).
    I don't know how to change it and it's like i ruined my website.
    @Admin help me please,I am getting crazy.
    Hello can you please let me know your domain?
  • Oh never mind you already provided your domain above.
    Can you please delete the force https code on htaccess cause I want to compare your website with https and without https
    I suggest you to use Automatic HTTP rewrites! Below is an Article but According to @Admin this is for sites with poor coding :( but I think this is to save time.
    How to Fix Insecure Content on Your Website without installing plugin!
    Pics : 1&1 Hosting
    Today I'm going to tell you that how you can fix insecure content on your site WP, Blogger, Forums or every site if you have SSL and all css and images can served over HTTPS you don't need to code don't need to do anything just step up site to CloudFlare!
    If you are not using cloudflare then first setup.
    Let's begin!
    Open Cloudflare then visit https://www.cloudflare.com/a/crypto/yoursite.com Crypto setting found below the  Automatic HTTPS Rewrites like in below pics!
    Just enable and everything will be fine!
    Read more
  • edited May 6
    Pics : 1&1 Hosting
    Let's begin!
    > image
    But still remember if you enable automatic https rewrite and you have content on your website that can't be change to https you are still stucked with your mixed content problem.
    > > > Pics : 1&1 Hosting >
    > Let's begin!
    > Read more
    Yeah! I've mentioned above!
  • I'm not a fan of the automatic rewrites if you don't have to. Usually, you can just change your website settings or code to make it use HTTPS URLs itself. But either should solve the problem.
    Just like CNN do in 8 months!
  • Thanks for the solutions,I will try them.
    IT WORKED!
    Thank you @Ranakhas
    Pics : 1&1 Hosting
    Let's begin!
    > image
  • Weirdest Problem than ever!Now my site works,but whenever I try to login on Wordpress I receive error 508!
    Can anyone give a possible explanation/solution?
    Help please.
    > Help please.
    I think you should disable forcing HTTPS. Do not force traffic to HTTPS! First disable forcing then login to Dashboard change site URL from http to https this will resolve loop problem!
  • Maybe try switching to Full SSL instead of Flexible?
    I've faced similar problem to yours months ago, which posted here
  • ADD: #508 refer to system's resource limit (perhaps your daily hit maxed out?), try to optimize your Wordpress like what @Ranakhas stated above
  • @Ranakhas said:
    > Help please.
    I already changed it from dashboard to https,but I will also try what you said about force HTTPS.
  • @ChrisPAR said:
    @Ranakhas said:
    > Help please.
    Edit:Didn't work
  • @ChrisPAR said:
    @ChrisPAR said:
    @Ranakhas said:
    > Help please.
    Edit:Didn't work
    Please help me,I dont know what's going on,I really disabled HTTPS forcing and rewrite.
  • > @ChrisPAR said:
    > @ChrisPAR said:
    > @ChrisPAR said:
    > @Ranakhas said:
    > > Help please.
    > Edit:Didn't work
    Kindly changes to HTTP in PHPMYADMIN than Install a plugin insecure content fixer then Capture All AJAX call
  • edited May 6
    Sorry but I don't know.
    Could you kindly tell me how to change it in PHPMyAdmin?
    Thanks for all your help.
  • It worked!
    Even with HTTPS!
    The solution was:
    Thank you to everybody for their help.
    I thought I had changed it but I hadn't,the problem is Flexible SSL and you MUST change it to full.
    I am not sure but @Admin,could you please inform every user with an announcement that nobody should select Flexible SSL for Cloudflare(if not,I understand)?
  • > @ChrisPAR said:
    > It worked!
    > Even with HTTPS!
    > The solution was:
    Be in mind that Cloudflare only Encrypt connection between user and Cloudflare not between user to Server thus I recommend to install Let's Encrypt signed certificate!
  • I understand it but I am not sure.
    For now,I am okay.
    Thanks again.
  • @ChrisPAR said:
    It worked!
    Even with HTTPS!
    The solution was:
    I didn't think switching SSL modes would solve it, but I'm glad it did!
    You should never use Flexible SSL on InfinityFree. Flexible SSL is only useful if the origin server does not support HTTPS. However, all websites on InfinityFree are HTTPS enabled by default, so you can always use Full SSL. Flexible SSL just leads to redirection issues like you just experienced.
    That's the great thing about using Full SSL: it doesn't just fix URL issues, it also ensures the connection is encrypted all the way from your visitors' computers to your hosting account. All sites are HTTPS enabled by default, so you can have a fully encrypted connection even without having to install anything on your account.
