Howdy, Stranger!
index problem How do I disable directory listing?
hello guys
my site www.blogcunuz.ml/wp/
www.blogcunuz.ml directory listing i wanna see my site on homepage .ml
wordpress settings done what i need? change htaccess?
Comments
  • my htcaccess
    BEGIN WordPress
    RewriteEngine On
    RewriteBase /
    RewriteRule ^index.php$ - [L]
    RewriteRule . /index.php [L]
    END WordPress
    Options - Indexes
    still dont working www.blogcunuz.ml :(
  • @blogcnuzz said:
    hello guys
    Just add Option -Indexes on your htacces
  • @blogcnuzz said:
    hello guys
    Your Address is still www.blogcunuz.ml/wp/ but now www.blogcunuz.ml is redirecting to www.blogcunuz.ml/wp/ I suggest you to move your files from /wp/ to htdocs main folder then update your site name in PHPMYADMIN SQL in wp_options change siteURL from www.blogcunuz.ml/wp/ to www.blogcunuz.ml also do this with homepageURL from www.blogcunuz.ml/wp/ to www.blogcunuz.ml
    Or
    First update URL in General Setting in WP-Dashboard then move content from /wp/ to htdocs
  • The best thing to do is to check the installation settings BEFORE installing, so you don't end up installing a website to a subdirectory when you don't want to.
    You could either reinstall the website (and this time make sure the Directory setting is correct!) or update the URL (which is more complicated).
  • Thanks guys i will try and write reply again :)
