Howdy, Stranger!
My web show "Congratulations! Your website is up and running", help please.
edited May 13 in Support Forums
HI,
Mi web shows this message "Congratulations! Your website is up and running". I delete index2.html . Then my web show me it
Directory Listing
Icon Name Last modified Size Description
[DIR] wp/ 2013-09-25 00:18 - [unknown item..]
[ ] files for your website should be uploaded here! 2018-05-05 13:48 0 [unknown item..]
Help.
Here, my web dominio : http://www.electronicwave1992.epizy.com
Comments
  • edited May 13
    Hello,
    You have installed Wordpress in /wp folder,so your domain is http://www.electronicwave1992.epizy.com/wp/
    If you do not want that you should re-install WordPress from Softaculous and remove the /wp so that it is installed to the root folder.
  • @anunaki said:
    HI,
    Directory Listing
    Help.
    If you don't want your site to show directory listing please create a .htaccess file if there is no .htaccess file there.
    And insert this code:
    Options -Indexes
