I used this technique for making a DDoS tool.
In which you used multiple web workers to send fetch requests?
It would be better to rent a VPS and use Go to send multiple concurrent http requests to the server
Still, mine dominates because it uses Typed Arrays
I been thinking about how some people are here on this topic more than othersâŚ
Just a thought
It depends on what you mean by âon-topicâ.
I meant that some people reply here more than any other topic combined. Just a thought I had on this boring day scrolling threw here.
mhm, cuz IDK much about cloudflare and stuff. If someone asked something about JS, I would almost certainly help them (if itâs vanillajs and not anything else, tho, cuz I donât do libraries or frameworks).
Ah, makes sense. HTML and CSS are what I know best, and you can find some dumb answers from me on other topics if your search my profile (please donât do that).
Challenge accepted.
:sigh:
XD, my Dad blocks ad services.
Canât do anything about it, anyways
When will this thread die down⌠tis a big thread!
Why do you wait for it?
why my css no work
Fix it?
Looking at the css code this is how it is supposed to work.
u confused meâŚ
Are you and ItsGamingTube related? Both of your sites seam to be this celixhost thing. BayoDino meant that your CSS is supposed to do what it is doing, I can check it out in a PC later to verify though. You can try clearing your cache.
It is doing its job, from the looks of it.
<div class="section1"></div>
Ewwwww, use <section>
instead
It is called
s e m a n t i c s
why my css no work
What doesnât âworkâ?
Youâd think someone with a regular member status would know this
