Hello all,
I am trying to re-deploy app once-worked-here with freehosting (account epiz_29470932).
When running my sql scripts via phpMyAdmin, I get the following error message:
#1142 - REFERENCES command not allowed for user: 'epiz_29470932'@'192.168.0.6' for table 'my_table_name'
Based on [1] I have understood that this is not supported for freehosting because of used storage engine (InnoDB vs MyISAM).
Although, When I tried to query the used storage engine I get the following:
SELECT ENGINE FROM information_schema.TABLES WHERE TABLE_NAME = 'my_table_name' AND TABLE_SCHEMA = 'my_db'
ENGINE
InnoDB
When I tried to add privilege based on [2] I get:
GRANT REFERENCES
ON my_db.*
TO 'epiz_29470932'@'192.168.0.6'
#1044 - Access for user 'epiz_29470932'@'192.168.%' to database 'my_db' is not allowed
I can remember that even this year (07/2021) this was working on freehosting without any need to perform any additional actions (I deployed epiz_29136812 with foreign keys without problem).
When did this storage engine has changed for freehosting based on [1] please?
If it indeed changed, why can I see conflict with my query for used engine?
What am I doing wrong please? Is there a solution for freehosting please?
Thank you for your help.
[1] Permissions error when creating database
[2] https://dba.stackexchange.com/a/135595
