Additional information:
403 forbidden nginx
i have been facing this seen i change my nameserver to cloudflare name server and a add a new cname,a, mx record
although a friend told me it might be permission so i change cpanel permission to 755 and i work for an hour now it not working please help me
I checked your DNS settings, and I see you’ve pointed your domain name to the IP address 185.27.134.9. However, that is the IP address of the server hosting the file managers, not the IP address of the server which is actually serving your website.
Please follow this guide to find the actual IP address you need to use:
Change the IP of your website to the one you can find on the guide Admin posted above via your Cloudflare DNS Page, then wait a while and clear your browser cache if you still see that error.
I checked and your domain also points to 185.27.134.9, which is the file manager server’s IP. Please remove the records that contain it in the same page of the Cloudflare dashboard.
It wouldn’t say that if you already added the IP of your website’s server. You just need to remove the records that contain 185.27.134.9 as IP, and then flush your DNS cache after a while.
