You can use a chat script that is hosted somewhere else and provides a widget of sorts that you can embed on your website.
Found these examples in a fast search:
This search was probably to fast since some of the ones in that list are hosted in the user’s server and are not allowed here.
But the ones that provide an embedable widget are OK.
Hello @PeterTekie
You are getting that 403 error most likely because you have a file with “chat” in its name. The server believes that files that include the word “chat” in there a me must host chat files. The easy thing to do is just rename the files.
Thanks.
Oh yes I know the problem when you make a file containing the word “chat” it gives a 403 Forbidden because chat scripts are not allowed in InfinityFree you may have to rename it.
