404!
We couldn’t find that page.
Please check to make sure you’ve typed the URL correctly.
This webserver is CaSe SenSiTiVe so ensure capital letters in the URL match the files uploaded.
404!
yes
Ok, your website is working fine for me
Please click Control + f5 or use an incognito mode to override your browser’s cache and view the live version of your site
What is the exact URL you are attemping to acess?
Can you use Incognito mode and access the exact page you just did
i did but still the same error appear
Can you use Print screen key (Prt Scrn) to show your entire window istead of just the browser
can you clear your DNS cache?
i tried to use vpn the i worked
why ??
i don’t want to use vpn to access my website
how can i fix that
It will be your router/isp cache on their side, or your computer holding cache just wait
I tried to use vpn then it worked
why ??
how can i fix that
VPN means changing router, working like that means your DNS is cached, flush ur DNS cache.
I’m using win 10 how i can do this ??
google it?
i did it still doesn’t work
Then refresh the page by using Ctrl+F5?
i tried everything nothing worked
