If
Always Use HTTPS
Automatic HTTPS Rewrites
are turned on in CloudFlare
You need to
As .htaccess is causing infinite redirect
You do not use CF and .htaccess to redirect at the same time
If
Always Use HTTPS
You need to
Hopefully you can understand.
Already did this. Thanks!
2 hrs ago his problem was solved, due to isp caching issue he is unable to browse his website from home internet connection
