Hello:
I have a domain Name - www.mathsisland.cf
and every time I type it in I get sent to the infinity free 404 error page.
It has only been 36 hours since I added the ns1.byet.org, ns2.byet.org, ns3.byet.org, ns4.byet.org, ns5.byet.org to direct my domain name. I have run a DNS Propagation Check and all seems well so why am I getting sent to the 404 page? Do I need to reprogram the htaccess? I even cleared my dns catch so I’m at a loss here.
Thanks
Wizard
The site is working fine from here. When did you add the domain name to your account. DNS is a slow process, so after adding the domain to your account you may need to wait another 48 hours for the website to start working.
i found my site working on android phone but not on pc
Which means the site itself is working fine, but your PC is using stale DNS records. Which just confirms that patience will solve this problem for you.
I have the same problem on my website, but I can’t see it from any device. Neither your website.
still domain is not working
right now it is not working from android phone also
please checkmathsisland.cf/
earlier my site was working fine
but by mistake i removed my .htaccess file which was provided by infinityfree
till ten i am getting this error
I see an error on your site right now because you added it to Cloudflare but the certificate hasn’t been set up yet (should fix itself in ~24 hours). Beyond that, nothing unusual to suggest anything is broken.
everything going in vain
If it says you should wait 24 hours, please wait for 24 hours. Don’t revert your changes after 6 hours because it doesn’t work yet. DNS changes take time. That’s how DNS works. And DNS can work for you as well, if you give it the chance.
My site is visible from all browsers except Google chrome why???
It shows 404 error
At all rest places it works fine
It shows 404 errorAt all rest places it works fine
Your site seems working through my device (and also using Chrome browser), you might want to check it out again.
Offtopic: I found your site kinda useful, would you mind keeping it running?
Yes
I will
Thank you
Are you on android or pc
It’s PC,
Perhaps clearing your cache would somehow solve the problem
Thanks
