hey there, i am running wordpress till 4.8 it went fine, i updated to 4.9 and it popped up saying on all my posts 404 not found with some ifast hosting links.
check it out please asap
technaman.org
it isn’t a wordpress error
Well, your home page works but all other links are dead. Please check whether you still have a file called .htaccess
in the htdocs folder and whether it still contains this fragment:
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\\.php$ - [L]
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
If the file does not exist, you can create a new file with the name “.htaccess” (using a file manager is recommended) and paste the snippet above into it.
I have it the same lines… null
I just checked your website and custom URLs like https://technaman.org/sponsers/ are working for me now. What exactly is the issue you see now?
@Admin
I was able to fix it after removing some lines from wp-config.php, after that it worked just fine.
