404 unknow eror
no
just http to https redirect by a plugin
Can you disable that plugin?
Just go to filemanager and rename that plugin will do
I try to delete it
I deleted it, but nothing good happened
The same issue here for a couple of hours.
WP installation (via Softaculous) on vol17_1 redirecting to 500 Internal Server Error or 403 sometimes. no change in the .htacess code.
IP seems down now
What should I do now?
:expressionless: damn, what should i do
I had nothing to do with the website. I checked the site 6 hours ago and everything was fine, but two hours ago when I opened the site again, I encountered error 500.
Isn’t it strange?
I kind of suspect it’s not your issue now. I saw three(including this) topics about the same problem. and my old website(which I don’t really use it anymore) that I haven’t touched for 2 months has 500 Error too. Sometimes even Timing out.
about errors:
I assume you are using the nulled version
because as far as I can see here the latest version asks for an active license
or the old version doesn’t work on PHP 7.
It is also possible that you have been hacked
Possible Outage?
nvm, works now.
s**t
Looks ok now
