Trying to make one but the error below keeps happening
Your domain is not yet pointing to ns1.epizy.com and ns2.epizy.com . Change your nameservers at your domain registrar and wait a few hours. You can also create an account with a subdomain first.
I am not trying to connect a domain. I am trying to get a subdomain and I get this error. (Error is above)
Hopefully, someone can fix this or help me.
Oxy
October 2, 2020, 10:25pm
2
Hi and welcome to the forum
To start, pick/select one of the free subdomains instead of the domain you specified
But if you want to have a subdomain of your domain, like sub.42web.io
Here is a photo to explain more. Also, I am not trying to connect a domain.
Oxy
October 2, 2020, 11:22pm
4
I told you everything in a previous post.
In order to create an account you need to either add a domain
or select one of the free subdomains…
According to your image you want to create a subdomain ahstudio.42web.io
To do this :
you must first point the 42web.io domain here via our NS
add 42web.io as addon domain
create subdomain ahstudio(.42web.io) in subdomain section of Control Panel
42web.io is a built in subdomain just to let you know , and it appears to be down
Admin has now posted an article regarding the situation of the 42web.io domain. Please read that:
Since the 2nd of October, the domain 42web.io is down.
Subdomains of 42web.io are unreachable
With 42web.io itself being unreachable, all free subdomains of 42web.io are unreachable as well. There is sadly no workaround for this.
If you do need your website to be reachable urgently, you can of course create an additional subdomain for your hosting using another domain name. You can do so through the Subdomains section in your control panel.
What caused this issue?
We suspect that the domain…
system
Closed
October 22, 2020, 5:03pm
9
