battlenet
epiz_28759666
ftp
530
login details are correct but unable to login to server
An FTP 530 error means the details are incorrect. Please make sure you copy the details from the client area.
[TigerMANEK426] I did not ask what it means!
Please pay attention !
@battlenet, technically, you didn’t ask anything, so we don’t know of you want an explanation, a solution, or something else entirely.
That error means the credentials are incorrect. Make sure you are getting them from the client area under the FTP header. Your FTP credit goals are different form your login credentials
(And no, its not a bug)
Thanks.
Maybe change the password again, wait 24 hrs and try again. If that doesn’t work, then it is probably caused by the outage.
I am paying attention, im telling you why you can’t login into the server.
Did you try all the options from this article already?
Sometimes the FTP account is not activated correctly and sometimes the password isn’t set correctly. Sometimes, people use the wrong password to begin with (like using the client area password instead of the hosting account password).
