Ah, oops, I didn’t actually check the KB link, it went to a different article than I thought it did. The article I thought it linked to is this one:
Cloudflare is a company. iFastNet, who builds the free hosting platform, is a company. InfinityFree, which provides the client area, is a company. And then there are the various SSL providers, which are also companies (or at least organizations, Let’s Encrypt is not a company).
My recommendation is going for the Full SSL route with a self signed certificate, which I linked just before.
Flexible SSL is also a valid option, and so is going for the free SSL along with “Full (strict)” mode. You can go any of those routes too, they are not wrong.
How to get full SSL…?
Right now i have applied for the SSL which is on the top of my dashboard in infinity free…According to your first image…i did it automatically ? after that what to do…i have to go on cloudfare ? from here i am not understanding…
if you have any video…regarding this same guide step by step…then please share…
After installing it…i have to go on cloudflare ? ? if yes then please give me full video of self signed ssl certificate install & then configure cloudflare ? step by step… please
We don’t have any video tutorials ourselves, only written guides.
I’m not sure how I can say this without coming across as very mean, so I’ll just tell you what I’m thinking: did you actually read the article? Not just look at the images and made up the rest yourself? Because the article is literally a step-by-step guide on how to do this.
And even then “I have to go on cloudflare”? The article literally has screenshots showing settings in Cloudflare’s panel you need to edit. So yes, of course, to edit the Cloudflare settings you have to go on Cloudflare.
It’s a written guide. All the steps are written down as text. The images are there to support the text, not the other way around. The images are there to help you find the right buttons, but not every single step has an associated image. Which means you’re actually supposed to read the text.
Read the article. It’s literally a step by step guide.
What i did… Step 1-I’ve first installed Full SSL certificate from the infinityfree hosting Dashboard…ok
now…i am confused what to do in cloudflare…i’ve to add a website in cloudflare ? then update name server to my domain of cloudflare ??
the full SSL certificate is from i’ve got lets encrypt…i want go get ssl ? how to change ?
now i’ve installed full certificate from dashboard…its showing secure…
if i will go to cloudflare then again i will do it for cloudflare ssl…then it will be double process ? i dont understand…or both process are linked to each other for secure connection…please explain…KangJL
I did. All I see was “please give me a video guide” and “please give me step by step instructions”. To which the answers are: we don’t have it, and you’re looking at it.
What I didn’t understand is what part exactly you needed help with. And if I understand this last message correctly, you’re looking at both guides and are unsure how they combined, i.e. which steps of which guide do you need to do in which order.
The answer to that is, you first need to do the “Set-Up Cloudflare” from this article, and everything until “Set Cloudflare to Full SSL mode” from the Full SSL article. After that, I suggest to follow the other guide, as this guide continues with Flexible SSL, which you don’t need.
If you intend to use Cloudflare, I would suggest to use a Self Signed SSL certificate, because you don’t have to renew those. To do, simply follow the steps of “Get a Self Signed SSL certificate” of the Full SSL article.
As to why you’d want a GoGetSSL certificate when you already have a Let’s Encrypt certificate, I don’t know. They are both fine free SSL certificates that are valid for three months, but Let’s Encrypt is easier to use than GoGetSSL.
If you have added a self signed certificate, then you can configure Cloudflare to use “Full” mode for SSL
You can’t manage the nameservers of your domain in Cloudflare, that’s not possible. As for the other settings, set them however you want (Except for the SSL mode, set that to “Full”)
