hello, my username is epiz_26012033 and i am getting a error that a trusted ssl certificate was not found and i am unable to install wordpress on my website but when i visit my website it says that it a valid certificate https://universaltoons.ml and this is the image of the error
Hello there,
That’s probably because of the Incomplete Certificate chain. The thing is that you cannot upload a CA_chain/CA_bundle or the Certificate Authority’s certificate here but don’t worry you don’t need it since most browsers nowadays doesn’t need a CA_chain.
You can ignore the warning and continue to use https anyways since your site does have an SSL certificate already installed so it should work fine.
It will work fine, everything will be fine.
You have to put a SSL certificate to do it, once done, use HTTPS
