About Directory listing
Hello i am new with infinityfree and web think and i want to create a website. I created a website last time here and after i publish it it says congradulation your site is published. but it doesn’t load my page it loads infintyfree congradulation page again and again. In that page it says delete index.html from htdocs and i delete it from there and publish the web again but now it sais “Directory listing” and shows the htdocs folder contains. So what should i do to overcome this problem and run the website?? please help… Thanks
You need a file called index.php or index.html which has your main page. Called the file anything else means it will not be recognized as the main file of the folder.
How to set up my page? When I open it appears DIRECTORY LISTING.
How to set up my whole page?
See:
Thanks admin i solved the problem thanks for the reply.
3ciclo you must download index.php from your database, edit and reupload it again for the website work.
