So for all the plugins there’s all the ways to make the site less vunerable / safer from hacking. One was to change the WP login name, which I’ve done. I’ve also tried to get SSL through Cloudflare (which probably isn’t helping).
Currently I can get into my WP-Admin panel by having Cloudflare in dev mode. These are the plugins I have. When I click ‘customize’ I get the spinning cog forever more.
Can you try disabling all your security plugins and try again?
I have a strong feeling it has to do with your security plugins since only you have access to /wp-admin and not us. CloudFlare works fine with InfinityFree but it is possible for it to malfunction other security plugins.
I’ve disabled the security features in Word press but it still doesn’t work. It could be because the DNS files are now rooted via Cloudflare fulltime. But even in Dev mode it still gives me the spinnign please wait circle of doom.
Is it possible to access the wp-login info from an IP address? Or does it have to be the domain address?
If the page gets stuck in a loading animation, my first guess is that it tries to run some complicated Javascript, but that this code has crashed.
Can you please take a look in the developer tools in your browser and check the Console pane while opening the page? You may see some error messages there.
