Hello
I Accidentally remove my free hosting . i go to Addon Domain Section in Control Panel …and click Delete…
Buy I can see in FTP that files not deleted. I wanna restore it help me.
Now i try create addon domain … in yellow i can see
Note: You must set your domains name servers to the following before adding the domain to this system:
ns1 epizy com
but after click to add Addon domain i can see Error Adding Domain…
and these:
This could be due to already adding the domain to this or another account or, you have not changed the nameservers as required or not enough time has passed since changing the nameservers…
Remember, you need to change the nameservers on a domain via registrar control panel BEFORE adding it to your account, it may take 24~72 hours to completely update the nameservers.:
Please verify your nameservers and/or change them to:
(The nameservers are changed via your domain registrar control panel, NOT your hosting control panel.)
ns1 byet org
Can some one explain to me i must set DNS to byet.org or epizy.com
Thanks,
That’s your answer
Either one works. You can use ns1-2.epizy.com or ns1-5.byet.org. They all use the same servers in the end, so it doesn’t matter.
