I thought it was real for a second
Actually i had a 2FA backed up but iām not sure why the codes donāt work. maybe thatās not for infityfree. but i can be sure itās for infinityfree because i named it so. Thatās the main reason i requested to have 2fa disabled. ofcourse no one would like to activate 2fa without a back up. i think admin would have to explain why my codes are not working.****
Because you are copying them wrong or the codes are invalid or already used earlier.
i thought so. but now im coinvinced the codes donāt work. i was typing them first but now i copy and paste ā¦ still getting same error message.
i hope so. otherwise i would have to change my hosting account next time i think of taking the trouble to build another eCommerce website.
I checked the codes you sent to Greenreader9 and they do not match the codes that we have stored for you. The format does match our codes, so itās likely that these were generated by us at some point, but they are no longer accurate now.
so that means my account cannot be recovered isnāt it. Since your platform says those were not the recovery codes given. anyways. thnks for your help. nevertheless those were the codes i copied from my infityfree page before activating my 2fa. if you say those arenāt the codes , i do not know what that means. if it is to mean that my website is lost forever since the hosting company cannot help recover my data , i understand. Thanks
I did check the 2FA activation page to see if there was any error with the recovery codes. I didnāt encounter anything that actually didnāt work, but there was one UX problem in that if you refresh the page or make an error when submitting the first six digit code, your recovery codes are rotated. If you then donāt store the updated recovery codes, you donāt have any working recovery codes.
This is not obvious, itās something I overlooked when building the page and I do intend to fix this ASAP.
I think that you may have fallen victim of this as well. I do want to make changes to make sure that this wonāt happen to other people, but I still cannot disable 2FA for you.
If you cannot disable 2FA, then resend me working recovery codes because the ones i copied from your site do not work. I have made some few references and have come across few people that passed similar complain about failing recovery codes. You need to fix this. Thanks
