For some reason my account was temporarily suspended for 24 hrs due to a random CPU spike. Is there a way to fix this problem? I have minimally resource intensive addons so this doesn’t make any sense. Please help if possible @Admin or any other user. Thank you.
This is probably due to a large increase of visitors, heavy codes would run once, for a bit of cpu, but if say 10 visitors at a time, loading heavy scripts, that could mean a large increase of CPU usage, what type of CMS are you using, Wordpress or your own PHP code?
It looks like one day you has 5,000 hits, enough to generate large CPU usage
Im only using Wordpress with minimal plugins. Thats why it was so strange. I don’t have heavy traffic, it was only me on the site that day, trying to make it look good, and writing my first blog post. So I’m guessing it just glitched really hard for some reason.
Refreshing your site everytime you make a changes can also cause a random cpu spike. Did you know that all of the Wordpress links including the dashboard and post editor are made of .php link and script, which is bad.
Please note that if you use Google Analytics to keep track of no of visitors, then you should know that Analytics only tracks those that have enabled Javascript in their browsers. This means that Analytics often does not keep tracks of browsers that have Javascript disabled, or bots that are meant to send traffic to your website. If you use Cloudflare, compare the traffic there from Analytics. Cloudflare represents the actual number of times a request was send to fetch your website from the server. That is the actual traffic of your website.
Fortunately due to the security system, it is hard for bots to crawl your sites, and for visitors who don’t have Javascript enabled, you cannot access the site!
Thank you for the help, but I just started my website a day or two ago, without linking anyone it. I would assume i was the only one on it, much less it getting botted.
