Hi, I Want To Add TXT Records To My Website, How Can I Do That? ( Without Use CloudFlare ). Thanks.
Upgrade to premium hosting
SPF can really be used as TXT? It won’t cause an issue with something?
Yes they can.
I got it from here:
And here:
That was said for SPF txt record.
You can’t add TXT records. That SPF records section is just for adding SPF txt records.
You will need to use some other DNS provider or switcher to premium hosting.
Ok Thanks!
