Basically I want to use my own domain for my site but also wanted to use the nameservers of my current registrar. So I have changed my nameservers to InfinityFree and added the domain through the “addon Domains” button in the client area.
On ftp I how have my main Domain htdocs folder and a new folder on the same level with a htdocs inside and added my files here so my new domain works fine.
But can I now change my nameservers back to my original registrar?
This article says I can use A records to show my domain
Do I just need to change the nameservers back to my old registrar
will that matter if ive added my site files to new-site.co.uk/htdocs or do I just need to add my site files to the main htdocs folder for my main domain?
If you added a domain through the “Addon Domains” section of the Control Panel, you need to upload the files on yourdomain/htdocs, instead of using the default htdocs folder.
