I cannot add my site to Cloudflare, and I am really confused. I already added one of my sites to Cloudflare and it works. The website in question is (hidden to protect privacy). The error I am getting is:
Failed to lookup registrar and hosting information of (hidden to protect privacy) at this time. Please contact Cloudflare Support or try again later.
I already looked at the Cloudflare documentation, but it doesn’t give a solution that works. I got my domain from freenom.com.
Sometimes I also got the error. But I tried clearing my cache and changed my dns nameservers. I also waited for the nameservers to be stable, like populate across every continent. Sometims I just point the nameserver to cloudflare prior to 5 hrs before adding in CF. Then add the records needed.
how did you know which Cloudflare NS to put in if you failed to add a domain to CF?
this process only goes later once you add the domain to the CF
you cannot arbitrarily put some NS of CF
but only that pair that Cloudflare generates for you during the process
Put SSL on my site, still can’t add it to CF.
The only NS on my site are ns1.epizy.com and ns2.epizy.com. Same error message as before.
Can’t get WHOIS info from who.is but I can from whois.com.
