After installation of WooCommerce Plugin its given error
Error " Your installation of WooCommerce is incomplete. If you installed WooCommerce from GitHub, please refer to this document to set up your development environment."
Old version also try but its also given error " Installing Plugin from uploaded file: woocommerce.3.7.0.zip
Unpacking the package…
There has been a critical error on your website. Please check your site admin email inbox for instructions.
Learn more about debugging in WordPress.
As you can see by searching the forum, this is a very common issue with WooCommerce:
https://forum.infinityfree.net/search?q=There%20has%20been%20a%20critical%20error%20on%20your%20website.%20Please%20check%20your%20site%20admin%20email%20inbox%20for%20instructions.%20order%3Alatest
You’re not even the first one today to ask about this.
The solution is the same as with everyone else though: install the plugin by hand instead: Manage Plugins – WordPress.org Documentation
