after upgrade to premium , can i configure php.ini ?
Yes, you can
Of course. Premium hosting comes with things which free hosting has limited.
Note: Shared hosting does not have PHP.ini access. You will need to upgrade to a VPS or dedicated plan.
Please correct me if I’m wrong here.
You’re wrong
FYI, cPanel does have settings for PHP which do alter the .ini
file.
Premium hosting has more options to customize PHP settings than free hosting, but not everything about the PHP stack can be customized. So it’s not possible to give a decisive yes or no to your question.
Can you please elaborate on what exactly you want to change in the PHP settings? We can probably give you a more specific answer if you ask a more specific question.
