My ajax calls arent working, when searching from database and printing them to the front end using AJAX GET request.
Fatal error : Using $this when not in object context in /home/vol15_8/epizy.com/epiz_23862135/htdocs/engine/plugins/micro/session_management.php on line 12
Try fixing this first, and if it still does not work, please send the AJAX code here.
And, as always, censor out sensitive information!!!
We are not responsible for people stealing your code as a result of you forgetting to censor something.
If you do accidentally post it, edit the post and then ask a mod right away (Greenreader9 is now one) to remove the pre-edited post (people can view edits and the unedited post unless mods remove them).
I’ve tried fixing that, there’s no change. However thats a negligible error, for the function in the file was meant to be called in several class methods which have that mention variable
That is weird, unless you have PHP installed incorrectly, or setup differently from the servers here (The latter is more likely). The servers here are setup to catch all PHP errors, to prevent exploits from happening.
In order for you code to run properly, it must be valid PHP.
The other parts are now working fine now. I have one other AJAX Request not working, I dont know why. Try signing up for mysquavero.ga , in the profile section there are posts and a “heart” button is not responding as intended. It might truly be as you say, but I cant figure out where exactly to revisit since it loads well on my PC’s localhost.
