well has no errors but base64file 1 and base64file2 are still ‘undefined’ in my java script on F12 console ,I have had enough today cant move this on as its syntax correct. But does not provide expected results of base64 code like it did on my other server idk why?
Hi Edwin hmm , not with my code its still not forcing the upload of image through PHP fopen( either
Am still noticing things like strlen( and other ‘c’ derivatives don’t work in php either its most odd
The only thing i have is from here a warning
Audit usage of navigator.userAgent, navigator.appVersion, and navigator.platform
A page or script is accessing at least one of navigator.userAgent, navigator.appVersion, and navigator.platform. Starting in Chrome 101, the amount of information available in the User Agent string will be reduced.
To fix this issue, replace the usage of navigator.userAgent, navigator.appVersion, and navigator.platform with feature detection, progressive enhancement, or migrate to navigator.userAgentData.
Note that for performance reasons, only the first access to one of the properties is shown.
Google Chrome seems to be going through some depreciation again I fixed this last time by going from Navigator.AppAgent to Navigator.userAgentData but it seems we are loosing that too maybe ? There is not much information currently about this new issue is there any information out there as this prototype.js file is no longer being updated from 1.7.3 that i have located ?
Also, please don’t discuss the same issue in multiple topics, because (as you’re seeing here) it’s very easy for important information to get lost and waste everyone’s time.
Please pick one topic to discuss this issue and keep all the talk in that topic.
iwas using “<img id=#np_track_artwork src=/images/nowplaying_artwork_2.png?t=”+$time+" alt=‘Playing track artwork’ width=200 height=200>" do you suggest i try with version not t?
I don’t know what you are suggesting @EdwinTigor , but you are messing things up that were working originally.
@anon14276620, I would put your SQL code back the way you had it before. Then, since you have completely lost me, please paste your code, and any error messages you have, here.
Am also getting Error occurred:SQLSTATE[HY000] [1203] User epiz_33087480 already has more than ‘max_user_connections’ active connections with $con=NULL is this not closing connection please in PDO?
