Hey, so I’m just wondering if there’s any way my website https://tomtof.cf could redirect to a website that doesn’t have to use the entire subdomain like a redirect.tomtof.cf/test and so on without just using the whole sub domain for one link.
Since you are using CF, you can consider page rule???
The Redirects tool doesn’t have an option for this, but there are plenty of options you can go for to create a redirect on your own.
First of all, you can create a file with the name .htaccess
in your htdocs folder or edit the file if it’s already there. In that file, you can add lines like this:
Redirect /test https://infinityfree.net
And that will redirect http://example.com/test to infinityfree.net. Feel free to replace with your own path and target URL.
