Arduino Sim900 problems accessing the database
I have an Arduino Mega 2560 and a SIM900 GSM GPRS Shield.
This is my first project with a database and I’m trying to post some values into it. I’ve followed a lot of tutorials on youtube but with no success.
I’m trying to apply here one of the codes I found wich included an arduino code:
#include <SoftwareSerial.h>
SoftwareSerial gprsSerial(10, 11);
void setup()
  gprsSerial.begin(19200);
  Serial.println("Config SIM900...");
  delay(2000);
  Serial.println("Done!...");
  gprsSerial.flush();
  Serial.flush();
  // attach or detach from GPRS service
  gprsSerial.println("AT+CGATT?");
  delay(100);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
  delay(2000);
  toSerial();
  Serial.println("------------------");
  Serial.println();
  // bearer settings
  gprsSerial.println("AT+SAPBR=3,1,\"APN\",\"movistar.es\"");
  delay(2000);
  toSerial();
  delay(2000);
  // bearer settings
  gprsSerial.println("AT+SAPBR=1,1");
  delay(2000);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=2,1");
  delay(2000);
  toSerial();
void loop()
   // initialize http service
   gprsSerial.println("AT+HTTPINIT");
   delay(2000);
   toSerial();
   // set http param value
   gprsSerial.println("AT+HTTPPARA=\"URL\",\"http://josepmorarduino.epizy.com/write_data.php?data1=2.88&data2=2.93\"");
   delay(5000);
   toSerial();
   // set http action type 0 = GET, 1 = POST, 2 = HEAD
   gprsSerial.println("AT+HTTPACTION=0");
   delay(6000);
   toSerial();
   // read server response
   gprsSerial.println("AT+HTTPREAD");
   delay(1000);
   toSerial();
   delay(2000);
   gprsSerial.println("");
   gprsSerial.println("AT+HTTPTERM");
   toSerial();
   delay(300);
   delay(10000);
void toSerial()
  while(gprsSerial.available()!=0)
    Serial.write(gprsSerial.read());
and also had a write_data.php
<?php
    $db['default']['dbdriver']='mysqli';
    $dbusername = "epiz_23486849";
    $dbpassword = "*************";
    $server = "sql307.epizy.com";
    $My_db = "epiz_23486849_arduino1";
    // Connect to your database
    $dbconnect = mysql_pconnect($server, $dbusername, $dbpassword);
    $dbselect = mysql_select_db("epiz_23486849_arduino1",$dbconnect);
    // Prepare the SQL statement
    $sql = "INSERT INTO pes (Value_1, Value_2) VALUES ('".$_GET["data1"]."','".$_GET["data2"]."')";
    // Execute SQL statement
    mysql_query($sql);
I put the php file in the folder “htdocs”.
My account details are as follow:
  • Main Domain: mkvatcdx.epizy
  • FTP hostname: ftpupload
  • FTP username: epiz_23486849
  • MySQL hostname: sql307.epizy
  • MySQL username: epiz_23486849
  • Hosting Volume: vol6_3
I also have created a website here: http://josepmorarduino.epizy.com as it shows in my account.
I think the trouble I’m experiencing is related to the arduino code, but I don’t really know whats the problem I’m having. Is josepmorarduino.epizy not the one I should be pointing at in the code?
My database has 4 columns: ID; Date_Time, Value_1, Value_2
The tutorial I followed was Tutorial : Arduino Save data to database using GPRS shield - YouTube but it is not in the same hosting environment.
If you feel like I missed any piece of information let me know.
Any help or guidance will be greatly appreciated. Thank you for reading.
Hi
okay thank you!
