You can view all of those values, as well as your usage, through the Account Statistics in your control panel. Those values are always up to date. How the CPU and RAM usage is calculated is not shown there, but that’s because we don’t disclose that information (you shouldn’t try to build your script to touch those limits, you should stay well within them). If a statistic is not listed in the Account Statistics, it generally means that there is no (hard) limit on them.
You can change your MX records through the section conveniently called MX Records.
Actually I managed to change the first and the last one. I only need to set - PHP Time Limit: 300
because the most popular Avada theme requires so.
Is there a way to change it?
No, the limits are configured like they are for a reason. Even though a script recommends it, most scripts will work fine with a lower time limit as long as you’ve got fast servers (like we do). And if your script truly needs it, it’s probably too heavy for free hosting to begin with.
