Hi
My database has around 150 tables (custom CMS and a forum). Some contain very little data (eg tables created for future features that haven’t yet been coded) while others contain a lot - eg an image library full of blobs for the safrane car made by renault…
I’ve had trouble importing those with a lot of data - they’re either too big or once uploaded the database (either phpmyadmin or mysql itself) then returns a parse error, times out etc.
So I tried the following SQL:
LOAD DATA INFILE ‘/accounts.sql’ INTO TABLE accounts
Naturally access was denied with a 1045 code (only a small table with 4 accounts in it though but it served as a quick and easy test).
So I’m still a bit stumped - obviously on a VPS or dedicated box I could root / admin in and sort it but on shared platforms I need a different method.
I do have one other way… I have code that takes each row from the table, base64 encodes every column and then transmits it to the server via a http post request (along with php code to execute the insert) however on some servers this then causes the firewall to block my IP - I get seen as a DDos’er apparently. Other than that, this method has worked well for me in the past on several servers where i struggled to upload data.
Any thoughts please?
Thanks
