Hi, I would like to know what should I do to redirect my original .ga site already taken down to another provisional site (an old free site) while I’m considering other new domain options. I’ve tried to established a redirect vía cPanel and also a forwarder in my freenom account but I don’t know if this is the best way and how long It takes to be effective.
Ok. I see. What a disaster, all the SEO lost! . Anyway, is there a way I can access my current wordpress installation again? , If so, what are the steps? Thx again for your support!
but it would be best for you to choose one of the free subdomains
and then move the existing WP there (via FTP)
and change its home URL to the new address where it is (it might be a bit complicated for a beginner all this)
If you’re switching to a new custom domain, you can just add it as a Parked Domain on top of your .ga domain, and then you don’t have to move any files or databases at all.
If you’re moving to a free subdomain, or have already added the domain as an addon domain, you will have to move the files to the new domain folder, but you can just leave the database as-is. If you just move the files and don’t change the database settings, your site will just keep using the existing database.
It’s not a bad idea to make an export anyways, because it’s always good to have backups, but you don’t need it to switch domains.
