I have been learning Bootstrap for a while now.
I have a whole page of stuff that I’ve been doing with it.
The below link is to the snippet that is not behaving correcting.
I have tried getting tooltips to work several different ways:
bootstrap.bundle.js
bootstrap.bundle.min.js
tooltip.js
popper.js
Nothing is working. All I keep getting is…
.tooltip() is not a function.
I made a short version of your existing code
I think some things are missing in your JS versions
I threw something out
something is unnecessary and most use external JS (CDN)
so you edit and download JS as needed ( locally )
and instead of the absolute paths from my code
make it (later) relative when you make your website/files
download this html file and run locally
and then use it (as help) to edit your code on the website
In a read-through and copying it over to the original page, it looked like you used non-local files and upgraded them to 5.1.3 vs my files which were 5.0. Ok, whatever.
The one thing I don’t get is…
<body data-new-gr-c-s-check-loaded=“8.888.0” data-gr-ext-installed=" ">
I noticed that and changed it shortly after I posted this.
It still errored out the same as before.
This would’ve been a JQuery error to be sure, but I don’t think it would’ve said that “tooltip() is not a function” for it.
MOF, doesn’t JQuery have a “tooltip” function also?
Not that it matters at this point.
