I cannot connect using MySQL Workbench.I’ve tried both:
- Put Default Schema (epiz_31909582_db)
- Leave empty Default Schema
As for the port I put 3306 as usual.
I tried to ping “sql205.epizy.com” but not success. If I open phpMyAdmin from the cPanel, the URL is:
http://185.27.134.10/db_structure.php?server=1&db=epiz_31909582_db&table=transaction
Then I try to ping 185.27.134.10 and got success. Then in Workbench, I change the Hostname to 185.27.134.10 but still not success
This is the my real DB and password (I’ll change later after I got answer from this post).
MySQL Username | epiz_31909582 |
HIDDEN BY MOD
|MySQL Hostname|sql205.epizy.com|
|MySQL Port (optional)|3306|
|Database Name|epiz_31909582_db|
