My website URL is: med-files.ml (my domain) , med-files.epizy.com/ (web site domain)
What I’m seeing is: I have a file named “help.med-files.ml”
I’m using this software: FileZilla Client (windows 10 64 bits)
Additional information: this file appeared after adding a subdomain. May one faith have to remove the subdomain file is stay. It is impossible for me to suppress it. Filezilla say
Command: CWD /help.med-files.ml
Answer: 250 OK. Current directory is /help.med-files.ml
Order: PWD
Answer: 257 “/help.med-files.ml” is your current location
Order: RMD htdocs
Answer: 550 Can not remove directory: Permission denied
Command: CWD /
Order: RMD help.med-files.ml
Answer: Can not remove directory: Directory not empty
Status: Retrieving the contents of the “/” folder …
Status: Content of the folder “/” displayed successfully
Answer: 421 Timeout - try typing a little faster next time
Error: GnuTLS -110 Error in gnutls_record_recv: The TLS connection was not properly terminated.
Status: The server did not correctly close the TLS connection
Error: Unable to read from socket: ECONNABORTED - Connection canceled
Error: Disconnected from the server
Status: Disconnected from the server
Status: Address resolution of ftpupload.net
Status: Connection to 185.27.134.11:21 …
Status: Connection established, waiting for greeting message …
Status: Initialization of TLS …
Status: Certificate Verification …
Status: Connected
Status: Retrieving the contents of the “/help.med-files.ml” folder …
Status: Content of the folder “/help.med-files.ml” successfully displayed
Status: Retrieving the contents of the “/help.med-files.ml/htdocs” folder …
Status: Content of the folder “/help.med-files.ml/htdocs” successfully displayed
Order: PWD
Order: RMD htdocs
Command: CWD /
