(epiz_26953513
artecks.rf.gd )
(Syntax error in domain name, to many dots.)
Good night. When I try to delete these bad records, I get the error message, but it doesn’t delete the record, the use of cloudflare has not been activated in the vistapanel/cpanel
These are the DNS records. I would like to delete them
CNAME Record
Destination
www.artecks.rf.gd.cdn.cloudflare.net.artecks.rf.gd.artecks.rf.gd.
destination.
artecks.rf.gd.
www.artecks.cf.cdn.cloudflare.net.artecks.rf.gd.
artecks.cf.
artecks.rf.gd.
The cPanel has always been dodgy with DNS records; I recommend using Cloudflare to manage your DNS.
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree.
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com ).
A video tutorial can be found at the end of this guide, should you get stuck.
You must connect your domain to your InfinityFree account first. Read more here .
Set-Up Cloudflare
Go to Dash…
If you would rather not, then we can try and solve this issue. Is there a specific error message that you see?
Admin
May 16, 2021, 6:04pm
3
That seems to be a bug in the control panel. I’ve asked iFastNet to investigate.
EDIT The records have now been removed.
They were not deleted, but now they can be easily deleted, Thank you so much
system
Closed
June 1, 2021, 3:15am
5
