Can You Help?
Hi, can you help me please? If I enter in my website URL dskillzmusic.com it works. When I enter URL www.dskillzmusic.com it does not work. I get Error 404 (Not Found)
Can you help me get this issue resolved? Thank you in advance for your time and help
Try using your domain manager to add a CNAME record for the www pointing to your site.
Hi john! Thank you for your reply. Can you please give me a little more details, which of the following 4 choices under DOMAINS do I need to choose?
  1. Addon Domains
  2. Sub Domains
  3. Aliases (Parked Domains)
  4. Redirects
Thank you again for your time and help in advance.
Sorry, I haven’t used the infinityfree DNS stuff. I prefer to manage it with the registrar for more control. I just had a quick look and they have a CNAME records option down under advanced.
Thank you so much john, you were very helpful! I managed to get the www to work under the CNAME records option.
