I’m trying to connect to my database through phpmyadmin but it give me an error that the page is not working
Does it give any information as to why the page is not working? Do you see any more detailed error codes or error messages?
no, but today I opened the phpmyadmin and everything is OK thank you
it gives me the error again and in the console this error shows up:
GET http://185.27.134.10/db_structure.php?db=epiz_20701338_hadithni net::ERR_INCOMPLETE_CHUNKED_ENCODING
I did a quick Google search for the error message and all results I checked say that the issue is caused by virus scanners blocking the page. The next time you see this error, please disable your virus scanner (or at least it’s web filter) to see if that allows you to load the page.
