Can't install wordpress (stuck at 1% for over 40minutes)
when I try to install Wordpress through softaculous it wont proceed over 1%.
A software installation is complicated and can fail for any number of reasons. It shouldn’t take more than a minute or so normally.
Did you try again later to see if it worked?
hey there, yes, now the installation went through. (I had to disable the automaitc-installation ofthe anti-bruteforce-plugin).
