Hi, I just uploaded my website http://villasanti.rf.gd but can’t display correctly.
All files and links are in order, don’t know why.
Kindly let me know, thanks.-
The problem I see is that the extensions of your images found in these folders
is in uppercase http://villasanti.rf.gd/imgs/
Please pay attention that unix based systems are case sensitive
Rename extensions to lowercase to reflect the HTML code
(Check all files in folders)
Hi,
Thanks I already renamed all the files but the problem seems like CSS files are not read at all.
Kindly let me know, thanks-
CSS has always worked well in my case, that’s why I didn’t mention it
Try deleting browser cache or use private/Incognito mode
All good now, thanks.
Two words: cache problems. Try to clear the cache and cookies and enable the cookies if you didn’t enable them in your browser.
I clear everything, the problem seems only on this hosting.
Other hosting works fine: http://villasanti.000webhostapp.com
Don’t know…
If you’re not sure
you can always test with some online tools such as
And if you look at the screenshots there…
it’s completely everything goes well to me.
can you use another browser or device? or VPN?
