ubuntu.rf.gd
Because this issus, i can’t put my XML sitemap to Google.
I’m getting this error: “Unsupported format. Your file appears to be an HTML page.”
I tried Yoast SEO, Google XML Sitemaps and All in One SEO, but I get every time the sam error.
I tried the curl command, but get this:
If you’re using PHP, do:
<?php
header("Content-Type: text/xml");
right before everything.
Most likely due to this…
sitemap_index.php = no such thing (404)
you need to give this URL to GSC https://ubuntu.rf.gd/sitemap.xml
assuming you added the domain as https to GSC
test
https://www.webpagetest.org/result/210209_DiCW_f9a857a5e58ad047d96f23dff13cd8cf/
nothing is blocked (gooogle can read it)
https://search.google.com/test/rich-results?id=ikpJZ1pvNSl0t4mBKj0TNg
then what is served is not pure xml
