Cloudflare error
Hello!
I want to use CloudFlare, but I already made an account with the infinityfree’s email.When I press Click to enable, it shows an error: CLOUDFLARE ERROR : Sorry there was a problem activating cloudflare for this domain or the email address, this is normally caused by the email address or domain name already existing on the cloudflare system.
I tried to connect my domain to clodflare, but I have the numeservers for infinityfree.I also changed the infinityfree email with another that isnt on cloudflare, but the same this is showing up.
my domain: dascalualexandru.me
What can I do ?
Thanks
This is error either happens because you have already added your domain to Cloudflare, which you shouldn‘t (since the panel will then do that automatically). OR, your you have a Cloudflare account with the same email you are using.
You do not need to connect your domain to Cloudflare when activating the feature in the panel, since it will do all the work for you and connect it.
Yes, I said that I have the same email.I wanted to delete the account, but I wont be able to create a new account with the same email.I also changed my infinityfree email, but the old email is still showing up
Please note that changing the email address in your client area does not automatically change the email of your hosting account. You need to go in to the Update Contact Email section in your control panel to update the email address there.
It worked, Thanks :smiley:
