But when I moved my NS’ to Cloudflare, I was getting an error “Too many redirects”, and when I switched to a default ns1.byet.org, problem resolved.
What just you tried??
Did you have any Always Use HTTPS settings or something like that enabled? That can cause redirect issues if your website is not configured correctly.
I’m hoping that you are gonna lose your SEO in few days if you don’t move site to Cloudflare Bro I you don’t known about HTTPS/TLS/SSL set up then first try Blogger.com for few days then try Infinityfree! As Blogger provides free SSL even for custom domain!
Dear, Let you know that I’m a “Top Contributor” of Blogger, It means I’m expert in blogger, but the problem with the Blogger is it is not Self-hosted.
OK! Let you know I’ve again tried to move my NS’ to Cloudflare’s. But still getting Error saying “TOO_MANY_REDIRECTS”.
And my site is not opening.
Do you have any solution for that?
@DhananjayS said:
Dear, Let you know that I’m a “Top Contributor” of Blogger, It means I’m expert in blogger, but the problem with the Blogger is it is not Self-hosted.OK! Let you know I’ve again tried to move my NS’ to Cloudflare’s. But still getting Error saying “TOO_MANY_REDIRECTS”.
And my site is not opening.Do you have any solution for that?
It doesn’t seem right I also very active on Blogger Support Forums blogger is not self hosted but I use Cloudflare even with Blogger sites to improve experience and auto fix insecure content with automatic rewrites HTTPS tool of Cloudflare! If you are blogger expert then why I don’t know you?
Hey I found somebody Named **Dhananjay Satanure ** on Blogger Support Forums with Level 7 on it! You are not expert at all bro!
Dear Rana Kashif Sarfaraz, when you left blogger support forum, I joined it. But in between, I left it due to my Personal reason.
Yes because I left it. (As I don’t accepted Google NDA (Non-discloser Agreement),
I left it.
And as I’ve been raised from Level-7, again now dropped to Lvl-7.
Hope you got it.
I left for study reasons I’ve to teach some students about Computer thus I don’t have time to maintain on Forums and mean while you know my site got blocked from infinityfree because of 600K views in one month that was a surprise for me as well! It’s a glad to meet you!
@DhananjayS said:
@Ranakhas said:
Hey I found somebody Named **Dhananjay Satanure ** on Blogger Support Forums with Level 7 on it! You are not expert at all bro!Yes because I left it. (As I don’t accepted Google NDA (Non-discloser Agreement),
I left it.And as I’ve been raised from Level-7, again now dropped to Lvl-7.
Hope you got it.
I got it, I’ll help you while applying Cloudflare via Team viewer or some other way as you want !
Dear,
As this is not our own forum please go to http://forum.learningwithexperts.ml
as it is My self-hosted forum. Where we can share our knowledge without any fear.
Please.
@DhananjayS said:
Dear,As this is not our own forum please go to http://forum.learningwithexperts.ml
Please.
Joining forums that the only thing that I love because I want more backlinks!
@Ranakhas, I think I’ve mailed you about that.
In my forum, you can freely create as many backlinks as you want.
But please keep in mind they should not decrease MY forum’s SEO ranking, right?
Please: http://forum.learningwithexperts.ml/10/installing-cloudflare-ssl-on-our-website
Dear @Admin,
My Wordpress Dashboard is not loading now.
https://learningwithexperts.ml/wp-admin
Here’s the error:
https://forum.learningwithexperts.ml/?qa=blob&qa_blobid=16562889846746052100
Please tell how to resolve this issue.
Please tell how to resolve this.
- Using Cloudflare NS’
- In “Crypto” tab of Cloudflare; Always use HTTPS
Redirect all requests with scheme HTTP to https. This applies to all HTTP requests to the zone." – is ON - Automatic HTTPS Rewrites
Automatic HTTPS Rewrites helps fix mixed content by changing HTTP to https for all resources or links on your website that can be served with HTTPS. – is ON - And I’ve also Created a Page rule “Alway’s use HTTPS”.
Then what is the error?
@DhananjayS said:
Dear @Admin,
My Wordpress Dashboard is not loading now.https://learningwithexperts.ml/wp-admin
Here’s the error:
Redirect all requests with scheme HTTP to https. This applies to all HTTP requests to the zone." – is ON- Automatic HTTPS Rewrites
Automatic HTTPS Rewrites helps fix mixed content by changing HTTP to https for all resources or links on your website that can be served with HTTPS. – is ON- And I’ve also Created a Page rule “Alway’s use HTTPS”.
kindly Check my Answer in Your Forums!
@DhananjayS said:
Dear @Admin,
Here’s the error:
The issue is that visitors are being redirected to https://learningwithexperts.ml/wp-admin, even when they are already using HTTPS.
I checked whether I could access your website while bypassing Cloudflare, and with that I was able to load the WordPress login page (including HTTPS).
I think you’ve set up so many redirects and rewrites it’s causing the redirect loop. Could you please disable Automatic HTTPS Rewrites (you don’t need it if your website is configured correctly) and remove the page rule? The Always Use HTTPS in the Crypto tab should be enough.
Dear @Admin,
I’ve now Changed my settings:
ONLY; Automatic HTTPS Rewrites
Automatic HTTPS Rewrites helps fix mixed content by changing http to https for all resources or links on your web site that can be served with HTTPS. – is ON
Still, the problem persists.
@DhananjayS said:
Dear @Admin,I’ve now Changed my settings:
Automatic HTTPS Rewrites helps fix mixed content by changing http to https for all resources or links on your web site that can be served with HTTPS. – is ONStill, the problem persists.
The one setting you definitely do not need is automatic rewrites. Please disable it because I suspect it’s responsible for this issue.
