I’ve tried the Cloudflare WP plugin but I don’t know how to use it in connection with infinityfree (since rather than a user in CF I followed the recommendation to activated it via the cPanel).
Any tips on this? Perhaps I should just give it a few hours to correct itself?
The website is rafamartinelli.com I do get a lock in the browser. I don’t know if I can clear Cloudflare cache because I’m using it via the cPanel, is there a way to do it?
Please let me know if you find out what the “problem” is, I would be so happy to get this SSL thing out of the way!
yeah,as I have assumed your site was on https but a lot of resources in its code are loaded as http and the browser naturally refuses to load anything that is not https That's why the appearance of your page is broken (blocked loading mixed active content) do as you have been told by MrJunior
Thank you both, your guidance has helped me fix this issue. I actually switched from another free host where I had ran into other complications with SSL also. But my https is working fine now thanks to you guys
I wonder about one more thing, and I’d like to take this opportunity to ask: I’m thinking of activating a second site with infinityfree+cloudflare; do you expect there to be any issues if I were to use the same email account (Cloudflare appears to not work via cPanel if the email is already registered)?
Hi there guys! It’s me again. After the downtime a few days ago my site rafamartinelli.com is still not showing up (getting error 522).
I’ve tried to fix it myself but found I’m not as savvy as I thought… I tried what was suggested in post Website still down, but couldn’t find where to modify the DNS (I did go to Registrar and I got the epizy DNS looking good, and this goes to CloudFlare – should I change something in CloudFlare via cPanel?).
Now as I’m writing this, the site is back up and I was able to update a couple WP addons, but after that it shows error 522 again.
