What happened to the Cloudflare integration in vistapanel? How do we use Cloudflare and Infinityfree? Is this no longer possible?
This has been discontinued because it did not work properly. However, you can still use Cloudflare! Follow this guide:
Note: It only works if you have a custom domain name, a freenom one is also good!
I know it only works if you have a custom domain.
Thanks.
