So yeah I am using cloudflare ssl because I have subdomains the thing is, I can not use SSL without VPN at some subdomains. My main domain is working perfectly but source.planetofplugins.ml and library.planetofplugins.ml requires VPN to work flawless, otherwise this is the error “ERR_QUIC_PROTOCOL_ERROR”
you wont be able to access directly to library.planetofplugins.ml and source.planetofplugins.ml so you can use this to visit website;
My Website’s URL: www.planetofplugins.ml
Also, I already read pinned topic but I don’t think this is an internal issue because it works with VPN also I’m using cloudflare not InfinityFree for ssl, if I’m wrong, correct me thanks!
when you use a VPN then you use their DNS
and when you are not using… then you are using from your ISP and your ISP currently still has old or none data
so you have to wait for DNS propagation as I stated .
only that REQ 8 is still looking for http instead of https,
did you make a purge cache on CF for those subdomains ?? WebPageTest Test - WebPageTest Details
And where exactly is that .htaccess file for error pages you edited stored ?
