What I’m seeing is: ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I’m using this software: Google Chrome
Additional information: I installed Cloudflare yesterday with “Full” SSL encryption mode.
Now my website is down, how long it’s going to take to show the Cloudflare SSL, did i do something wrong? Should i remove current certificate generated through your panel or i just have to wait?
You should use “Full” only if you have a certificate installed on your hosting account, while “Flexible” can be used if you don’t have a certificate installed on your hosting account. The difference between the two is that the “Full” SSL option will tell Cloudflare to connect to the server with HTTPS connection if you apply a HTTPS request, while the Flexible option will tell Cloudflare to always connect to the server with HTTP connection if you apply both HTTP and HTTPS requests. The second option is better used if you configure the script to use HTTP URLs, but then rewrite the URLs to be HTTPS in order for them to work even with HTTPS on, while if you have the first option, you don’t also need to set up WordPress to have HTTP URLs instead of HTTPS ones.
