Where should I add these CNAME record?
- In Infinity Vista Panel…under CNAME Records? OR
- In Cloudflare…under DNS?
Hello there,
If you’re using InfinityFree’s nameservers then you will need to add those CNAME records here in the Control Panel otherwise you will need to add those CNAME records directly on Cloudflare if you’re using their nameservers.
You should set the DNS records with your current DNS hosting provider (i.e. the provider whose nameservers are currently used on your domain). That could be us, it could be Cloudflare, or it could be another party.
If you want more clear instructions, can you please share your domain name?
